2007 c-280 mcsII comand repair?
thanks
will
im sure its not the building because once upon a time this unit worked great. it actually came with I think the audio 50 and I bought this mcsII from some guy off of ebay in 2012. was supposedly new. shes got the phone system also as well as the multi cd changer in the glove box and a satellite that she not longer subs to. at this time we probably would prefer to keep the OEM but that can change at a later date.
that alpine does look nice though. where would the amp be installed is she goes that route?
thanks
As for the problems you are having, the cd player not reading discs, would need repaired which i know no one that does it, as for a replacement, I had a friend at the dealership quote $4k for a refurbished. You can try calling united radio which is in your neck of the woods.
I don't think a software update will fix anything.
The gps antenna could be going bad, you can look on ebay for an aftermarket gps antenna with a round end and plug it in the back of the command and see if it works ok
thinking about it now, it sounds like a hassle, just replace it. i can recommend someone for you.
