Sponsored by: Innova
Driver seat not functioning well
Old Dec 12, 2015 | 02:49 AM
Musbahf's Avatar
E350 2011
I own an E350 coupe 2011, last week my driver seat got tilt at a 90 degree position and i'am not being able to move the backrest forward. Is there any solution for it? I tried to reset the seat but nothing changed. Thank you
Old Dec 13, 2015 | 12:24 PM
jbondox's Avatar
beater with a heater
I had to rebuild an S class seat from the digital controls to analog and physically had to move the seat a few times with just power to the motor. it should be 4 wires, the 2 thicker are the motor, try a 12v drill battery to it. The other 2 wires are varying resistance and is used to tell the seat module where it is at. it should be in the seat back, 2 t15's at the bottom. if not it is 2 tabs at the bottom that needs a flat blade to push up on.
also you could go to the dealer to relearn the seats electronics cutouts.
