Sponsored by: Innova
Replacing speakers from HK in CLS55
Old Mar 19, 2016 | 07:40 AM
kiwikid10's Avatar
CLS 55 & E55, Porsche Cayenne
Hi All,
I have a CLS55 2006 from Japan with the Harmon Kardon system.
Can I replace the factory speakers with aftermarket or are they different impudence like the bose systems?
Also I want to put a proper subwoofer in, is there anyway to intercept only the subwoofer signal and then use it for an aftermarket amp.
I have the capability and equipment to replace the whole system, but I want to keep the OEM look and be able to return to stock easily.
Regards
Jason.
Old Mar 29, 2016 | 03:35 AM
Dnasty's Avatar
2010 e550 coupe
Originally Posted by kiwikid10
Hi All,
Regards
Jason.
Not sure about the hk speakers impedance but as far as adding a sub in the trunk or whatever you can simply tap into the woofer in the back seat rack and run it to an amp or use a line output converter to the amp.
