Sponsored by: Innova
Drivers seat adjustment
Old Sep 17, 2017 | 11:45 AM
TheManGaz's Avatar
C220 CDi 2002
Unhappy Drivers seat adjustment
Hello to whomever reads this and thank you for doing so.
I have recently come into the possession of a C Class 220 CDi 2002 car.
Down on the right of the seat is 2 switches that adjust the seating position. Sliding the seat backward and forward is done manually. I have found that the 2 switches do not respond. The passenger seat is OK.
After some googling I have found the fuses and they are OK. i have checked the connections under the seat and they seem OK.
My question is, is there a relay located somewhere that could be causing the problem and if so where do I find it to get a replacement that might just solve my problem?
If you can help it would be greatly appreciated and if you can't then thank you for at least reading my post.
regards & Thanks
Gary
