Sound Unavailable/System Unavailable Then System Shut Down
Fuse 13 (I think) 20a was blown. I put a new fuse in and the system now works but the volume control does not work and the system does not turn off with the key. I have to manually shut if off with the power button on the audio unit.
Thoughts? is it possible that the Audio Gateway has an issue?
For those that follow me with this issue.....
The first fiber optic connection needs to go to the Bose amp and then to the Audio Gateway. Make sure you use the optical connector with the 4 pin that DOES NOT contain the large RED/YELLOW STRIPE wire for the Audio Gateway. I believe that one goes to the CD changer. I cannot confirm this because I have deleted mine but I have every other module installed and there is nowhere to connect it to in my setup.
Hopefully this helps someone down the line.
