How to remove Radio? (I used Search)
02 W163, 84 W123, 03 E39, 98 E39
I am not having a good day. First I couldn't get the 10mm bolts off to replace the starter on my 300D this morning, now I can't figure out how to remove my radio from my 97 C280.
I used the search feature and read about a MB Radio removal tool and at SLK23.com he said it could be done with a thin knife. I have two pieces of thin aluminum that just fit into the two slots, I push in about 1cm to get resistance, I push a bit more, and I can not get the radio out.
I pulled the coin tray below the radio, so that I could reach behind to get more forward force on the radio, but my jury rig radio memoval tools don't seem to be doing the job. Can any one post a pix of the MB radio removal tool, and let me know how far in I need to push the two pieces of metal? Any help would be appreciated. I don't want to be 0/2 today.
Thanks.
Steve
Thanks.
Steve
1996 S 420
You can find both here:http://www.perfectmarketaudio.com Follow the link on radio removal.
When using the correct tool, the tool will lock onto the radio so it can be pulled out.
Good luck.
Good luck.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: How to remove Radio? (I used Search)
Thanks.
Steve
Thanks.
Steve
Just use something thin and pointed (like a nail file or pointy pen knife). The tool slides into the slots, and pushes the catch to the side. It needs to push it towards the center of the stereo.
If you cut the metal to an angle, you will have better results. Like this:
Code:
(Without the tools, I once just cut two pieces of plastic into strips with angled ends and used those to get the radio out.)
-s-
Thank You!!!
Sura: The picture you directed me to, gave me the idea I could use a small knife and the pictures helped a lot to understand what was going on, and what I needed to do.
Scorchie: Your suggestion confirmed that I could use two of my small Swiss Army Knives, with the curve of the blade towards the middle of the radio, and it slipped out like a charm.
You kept me from being 0/2 today, at least I can claim a .500 average for my auto repair escapades.
S, GL, Escalade ESV, my shoes
Re: Thank You!!!
Why not buy the radio remove key and got the whole thing done in 2 minutes ? Dealer charge me $5 for the set. Not cheap, but obviously not too expensive.
Re: Re: Thank You!!!
W 000 589 00 63 00
-s-
