Sponsored by: Innova
swicthed POWER HELP
Old May 25, 2004 | 09:34 PM
r207's Avatar
w203
swicthed POWER HELP
I need to hook up a dvd player to the command and have no idea where to get the power from,
can i cut a wire out of the back of the command or use the power fom the tuner?????
NEED HELP SOON
Old May 25, 2004 | 10:11 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Switched power = back of lighter socket
I think you might not have gotten a response before because this was covered in the past... a search might have helped!
-s-
Old May 26, 2004 | 01:31 AM
r207's Avatar
w203
thanks, i was not really sure what i was looking for....
now i do...
What is better using the fuse block in the back or the lighter...or is it the same thing??????????????
Old May 26, 2004 | 03:23 AM
scorchie's Avatar
now i do...
Just use the power connector running to the lighter... it is normal spade connectors you can get anywhere (even in Oz I hope!) and tap into it. The lighter outlet is already fused so if you're just using it to power a DVD player or something, it should be fine.
-s-
Old May 26, 2004 | 03:25 AM
r207's Avatar
w203
thanks thats what ill do then, i dont think ive ever used a ligher in my life in the car
