Sponsored by: Innova
Need a liitle Question answered
Old Jun 4, 2004 | 03:28 AM
r207's Avatar
w203
Comand,
with the a conector what can i use to piggy back constant power off....can i just splice one of the existing wires,
also can someone tell me which wire is which in the A
THANKS
Old Jun 4, 2004 | 03:49 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Need a liitle Question answered
Originally posted by r207
Comand,
THANKS
I would not piggy back off the COMAND constant wire because it is a rather large wire and splicing/hooking in to it/etc. would compromise its current carrying capabities.
If you search around on this forum or in the web you can find LOTS and LOTS of posts about the pinouts of your COMAND (or regular Becker stereo for instance, hint hint!). I would just link you one now but I don't have one handy, so you can do a little work.
-s-
Old Jun 7, 2004 | 03:38 AM
r207's Avatar
w203
i give up, im gonna jut run it from the battery,
thanks for the reply, if you recomend me not using the comand what are the pinouts going to do for me........????????????????????
Old Jun 7, 2004 | 05:56 AM
miroj's Avatar
Old Jun 7, 2004 | 06:00 AM
miroj's Avatar
Connector B is not valid for BOSE [810] systems.
You have switched power, so you can tap into that without being too gregarious.
Permanent power for the COMAND comes from a dedicated fuse in the REAR sam module (fuse box). So if you need permanent power why not just run a fuse from the Electric blind fuse option with relay and then install the console switch.
This gives you the ability to switch from the main console. But only do it that way if you have money to burn.
Old Jun 7, 2004 | 09:54 AM
scorchie's Avatar
I dunno, you tell me... you asked TWO questions.
1) which can you get constant power from
2) "also" what are ALL the pins
So I thought maybe you could do a little research on your own.
-s-
Old Jun 7, 2004 | 07:17 PM
r207's Avatar
w203
-s-
yeh fair call,
its been frustrating the hell out of me trying to work this out, thanks for the help scorchie and miroj
Old Jun 7, 2004 | 07:25 PM
miroj's Avatar
yeh fair call,
Running power isnt a trivial matter so I wouldnt go taking it from an appliance circuit.
Besides you never said what it was for or the power requirements in AMPS.
If the drawing looks like gibbrish then I will suggest you take a copy of it to an expert and show them. Maybe someone can go through it with you in person.
