Sponsored by: Innova
ACC Power W211 - E500
Old Jul 3, 2004 | 09:22 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Does anyone know if there an ACC Power line/cable in the trunk area near the battery? I have a W211 - E500.
I am trying to hook up the XMRadio Commander 12Volt wire and it also needs an ACC connection as well.
Old Jul 3, 2004 | 09:28 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Most XM installations I've seen on the W211 ("hacked in" by your average stereo shop) have tapped into the wiring in the left side of the trunk. There's a whole bunch of things over there including the audio gateway; you should be able to find all of circuits 15, 30 and 58 there.
-s-
Old Jul 3, 2004 | 09:49 PM
ATS's Avatar
ATS
I was going to put the 12v cable to one of the wires in the distribution block in the trunk on the right side near the rear battery. The ground I would just put it under one of the nuts and tighten it down. Now the other thing I am trying to do is that the connector that goes into the xm box also requires an acc line....Where can i get that line/cable? If there is a acc line in the trunk - where abouts is it? On the left side someplace? Where abouts? I don't really want to start poking around and mess something up. I do not have command or keyless go on this vehicle.
Any help or diagrams/pics would be greatly appreciated.
Thanx............
