Sponsored by: Innova
GPS Antenna under Dash
Old Jul 5, 2004 | 04:52 PM
Tariq's Avatar
S500 W223 2021
Any one know about the GPS antenna which is stuck to the underside of the dash between the center vents and the instrument cluster.
I want to see photo in real position how and where is the best place from that place the antenna must be?
Its Urgent Am doing the work now Plz..
Regards
Tariq
Old Jul 5, 2004 | 11:39 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Regards
Tariq
Hi Tariq, sorry I don't have photo.
But the antenna goes right in FRONT and ABOVE the instrument cluster, not between it and the vents.
Pull the instrument cluster out using the cluster hooks. Insert the hooks into the slots in the front, then turn them towards each other 1/4 turn. That should release the cluster and let you pull it out.
Look back into the dash where the cluster is, you should see a plastic housing in the dash. The antenna goes between this plastic and the dash material. The Mercedes instructions say:
Originally Posted by Mercedes-Benz
Detach laminate film from the underside of the GPS antenna and adhere GPS antenna into the top opening in the instrument cluster cover.
The opening in the GPS antenna must point in the direction of the top side of the dashboard. The antenna line points in the direction of the steering wheel.
Hope that is helpful.
-s-
Old Jul 8, 2004 | 11:43 AM
Tariq's Avatar
S500 W223 2021
Yes Thanks alot really
It works...
My Regard
Old Jul 11, 2004 | 03:54 PM
wbupload's Avatar
2006 CLK 350
Cluster Hooks?
I am also installing the GPS antenna and would like to know where you get the cluster hooks to remove the cluster?
Any help would be greatly appreciated.
Old Jul 11, 2004 | 07:15 PM
scorchie's Avatar
dealership, ebay, samstagsales.com, make them from metal coat hangers, or push the instrument cluster out from behind (least likely to cause damage if you have an older CLK with the sissy vinyl covering the dashboard).
http://www.samstagsales.com/mercedes/mb140pullhooks.jpg
-s-
Old Jul 12, 2004 | 08:33 AM
wbupload's Avatar
2006 CLK 350
Thanks!
