Command Center - Bluetooth Unavailable
Settings > Activated Bluetooth.
Under Tel, I can see Connect Device as per the instruction manual, but I am unable to select "Connect Device". It is hard to see from the image below but it's greyed out. Cannot navigate with the rotation input or the navigation keys.
I read on the forum to try disabling Aux, but that did not help.
Any help much appreciated!
Jamie
I don't seem to be able to get into a pairing/search mode on the console.
I found modiles such as; http://www.mercedesmedic.com/mercede...tooth-adapter/
But I can't find anything like that located on the vehcile, just the AUX and USB port in the central storage.
Guess I'm trying to confirm if I require an add on or is Bluetooth built in...
It's driving me mad, thanks for your input btw.
