Sponsored by: Innova
W202 1998 illumination NOT WORKING for Cluster; Central Dash.
Old Dec 11, 2019 | 04:16 AM
Kameel2's Avatar
W202 1998
Good day
My W202 1998 instrument cluster illumination is not working including:
the illumination on the window switches; Gears; and central dash are also not working.
They all went out at the same time.
All bulbs and fuses are okay.
Could the fault be on the Dimmer switch (which has adjustments 3-2-1) or the Main headlight switch?
I doubt its the lighting control relay/module as everything else is working fine
Any advice would be greatly appreciated!
Old Jan 5, 2025 | 05:00 AM
MD105's Avatar
did you solve this?
