Sponsored by: Innova
2008 ML500 amplifier location
Old Aug 31, 2020 | 09:35 AM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
I'm looking into a sudden loss of audio on a friend's ML. The COMAND head unit works, but no sound. Diagnostics say that the MOST ring is open and I believe that the amplifier is position 1 in the ring, so I want to inspect it if I can. Does anyone know where it is located?
Also, is the amplifier on a separate fuse from the head unit? His fuse chart is missing.
Thanks!
Old Sep 19, 2020 | 09:09 PM
sarcazm1's Avatar
2004.5 230k
Under drivers seat. Take out the drivers seat you will get an airbag light/srs...Remove the door sill plastics and peel the carpet back. Its super tight. 10mm bolts holding the plastics then underneath theres a huge bay and the amp is there
