Infra Red / Door Locking problem
Old 11-14-2020, 11:17 AM
Flyinspanner's Avatar
W215 CL500, A209 320CLK
Hi I’ve posted in the A209 sub forum, but want to throw this out to a hopefully wider audience for assistance.
Yesterday our 2005 CLK convertible wouldn’t respond to either of the 2 remote keys.
neither doors nor boot.
open door with key blade and car starts fine.
doors will lock/unlock from dashboard buttons.
the 3 fuses listed for central locking are all ok.
tried new fob batteries.
charged the main battery overnight but to no avail.
Has anyone suffered this? Will it be the IR receiver on the door handle?
If so, how do I access, does door panel have to be removed, and does the unit have to be coded to the car if I can get a replacement?
Are there any steps I’ve missed checking?
any other control units?
Old 11-15-2020, 03:32 PM
Plutoe's Avatar
Received 1,024 Likes on 952 Posts
1999 E300TD
If you have access to DAS Xentry you will find the problem as soon as you do a short test. Otherwise your FUUAA will not work regardless of where you post
Old 11-15-2020, 04:19 PM
@Plutoe
All fixed.
It was fuse No.8.
not listed as part of central locking but it also powers RF amp.
what is the FUUAA you keep listing I’ve googled it and there are no hits?
is it an acronym you’ve made up?
Quick Reply: Infra Red / Door Locking problem
