Sponsored by: Innova
dash cam install s205
Old Feb 23, 2021 | 11:09 AM
jon big's Avatar
c class s205
Hi All
I am installing a dash cam into my c220 s205 2017 but have conflicting views to the location of fuse boxes . I have located one in the passenger footwell and was under the impression there was one located on the drivers side , side of dashboard (RH drive vehicle) also one in the boot space . All the images I can find illustrate removal of the dashboard compartment but without undue stress this cover will not release and am unsure now if this location is correct , maybe someone can shed some light on this for me please .
I would also be keen to know which fuse to piggy back off to enable the dash cam to turn off when ignition is turned off .
I have asked this question on some online social media sites but unfortunately the question leads to some quite stupid replies .
Old Mar 8, 2021 | 05:16 PM
realien's Avatar
2016 AMG GTS
Originally Posted by jon big
Hi All
I don't know your particular car, but in the past I have tapped of the rear view mirror. I've seen it used for a camera and for radar detector, I've used them for both. It doesn't help if you want a battery system to have the camera running once the car has shutoff.
Mirror tap amazon link Mirror tap amazon link
In other cars when I had a battery so the camera can run when the car is off for a few hours under a separate battery, If run it off the cigarette lighter fuse using a "add a fuse" adapter like these ,you can get them at your local auto parts store too.
add a fuse amazon link add a fuse amazon link
looking at the fuse diagram in the drives compartment for your car, it looks like you could borrow from either fuse 202 - alarm or fuse 446 in the trunk (cigarette lighter)
Fuse box locations
