Plz plz plz HELP!!!!
Ok... this is like my 2nd thread regarding my vss wire... This is whats going on.. I got the Avn2454 screen installed in my car looks Great ... But my installer Can not find the VSS wire... I LOOK EVERY WHERE.. EVERY WHERE....So i had to call alpine tech support and they told me that i have to buy a CAN BUS adaptor the part number from MB is Q-6-54-0011. Pretty much what this part does is supposly adapts on to a certain wire and converts it to become a vss signal. I do not want to buy this adapter for a 100 bucks and this adapter might not even work... So my question agian to you guys is that when you installed your Navigation, (Except the avicn1 which does not need a vss wire)... do you guys/ gals have any problems at all plz help me out thank you ( = I have a C230k 04...
Here are some pics ....https://mbworld.org/forums/c-class-w203/82161-my-new-toy.html
2003 Brilliant Silver C230 Sedan
Here are some pics ....https://mbworld.org/forums/showthread.php?t=82161
If you are willing to drive, the shop is in Walnut.
Erick, is the owner and both he and his wife drives Mercedes. they are rated as 1 of the top 10 installers in the United states.
Good luck JC C230K!!
So... Jw c230k are you saying that i will not have to buy that part from MB ... there is a way to by pass it? i thought u return your eclipse screen?
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Umm, there is a speed pulse connection on the W203, without using a CANBUS convertor (figure1a is correct in that the speed pulse is required by the car before this information can be placed on CANBUS). Why spend money to get parts that you don't need?
The reason you may have had posted three times without a response is because this has been discussed here in the forums... my suggestion is to do some thorough searching and you should be able to find the answer! If you don't want to do a little work and search for it, then you can spend the money to have it done instead... I'm cheap, so I would rather search for the answer.
-s-
-s-
