hello from Denmark
i am so stuck
Have a car with flashing right front light, fault in cluster with battery and SRS, radio and upper control flashing/goes out.
Xentry have a lot og codes and Can erros.
i have used: http: www.carlogic.org/bg/data/MB%20CAN(ICC).pdf last pages, to look at the network and i can get fault to stop with pulling one connector from Can B X30/4
Put in and all are flashing again.
Follow the brown brown/red and can see it goes out unter paasenger right to engine room so cant follow longer
messuring 40 ohms on connector pins.
Cant find a wiring diagram on X30/4
Sry about my bad English
