Sponsored by: Innova
Dead comand 2.0
Old Feb 8, 2005 | 03:44 PM
amerissa's Avatar
W211 MOPF 2008
Dead comand 2.0
A friend brought few years old comand 2.0 that is dead.
The display is black with no activity except the fan.
The fan seems to spin up and spin down a few times and then it stops.
Pressing the ON button will repeat the fan spin up/down cycle.
I tried the usual trick (on + * + #) but nothing.
It will accept a CD and will eject it on request.
We swaped out from a working unit the display and the CD drive.
This revealed there is no problem with them and the problem lies within the 'prozessor module'
Ideas anybody?
Old Feb 9, 2005 | 11:43 PM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
Not sure whtat "prozessor module" is but sounds like the Tuner Module is broken. I have the same problem with my US Comand and after SteveNL swap the Tuner Module (Euro), everything works. And now it speak British English and can in sync with my TV tuner.
Old Feb 17, 2005 | 04:44 AM
amerissa's Avatar
W211 MOPF 2008
The problem truned out to be corrupt or interupted upgrade.
Nobody offer a way to revive it effortlessly so I took it appart and progammed externaly the flash chip.
After much work, the machine booted and asked for the upgrade CD. 20 minutes later the comand was back in operation with the MY01 software.
If somebody needs assistant in retrofiting comands to MB or other vehicles in Greece send me a PM.
Old Feb 21, 2005 | 02:48 AM
amerissa's Avatar
W211 MOPF 2008
For sake of completeness - just in case somebody runs into the same problem as I did.
My problem occured because of a failed download. Infact the problem was in the SH (graphic) board.
The solution was to dismantle the board, unsolder the flash and load the s/w that I have previously read from a working unit.
When it booted with my SH flash image, I was presented with the "assert" error screen indicating that the SH and MCM s/w were not indentical.
I was lucky enough and this comand was of the upgradable type, therfore the MY2001 CD completed my repair.
While doing the above I realised a few things:
These boxes run linux.
The blaupunkt MCM chip is made by axis communications (www.axis.com)
It is propably the ETRAX 100 (not in poduction anymore but similar to the 100LX)
The DNL files on the upgrade CD are not pure image dumps - they need some conversion before loaded with a chip programer directly to the chips.
The fourth letter of the DNL file name indicates the type of the image:
"G" goes into the SH - graphic board
"M" goes into the MCM chip
The "G" file contains the start up screen (MB logo)
I've seen some posts of people modifying the 'G' file to change the logo with their own.
There! I hope somebody finds the above usefull.
