Fuel pump/module
Old Oct 25, 2023 | 07:53 PM
Darryn's Avatar
w245 B200 turbo
Fuel pump/module
Hi
where do I find the intank fuel pump/module.
I am aware that you need to replace the whole unit and that the pump does not come separate to the unit.
where is this located as I don’t see one under the back seat.
I have a W245 B200 Turbo
Old Nov 2, 2023 | 03:21 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
The fuel pump is in the tank. You can't access it unless you remove the tank and open it up. It is not servicable. There is no inspection hatch on the W245's to access the tank. Its painful. I changed one and some photos are attached.
Attached Thumbnails Fuel pump/module-20230215_104117.jpg   Fuel pump/module-20230215_104630.jpg   Fuel pump/module-20230215_104635.jpg   Fuel pump/module-20230215_104638.jpg
