Steering wheel vibration over bumps – W177 A-Class / W247 B-Class – seeking advice
Subscribe
Mar 29, 2026 | 10:55 PM
Hi all,
I'm experiencing a persistent steering wheel vibration issue on my Mercedes (W177/W247 platform) and hoping to get some insight from others who may have experienced something similar.
The symptom:
  • Vibration is felt through the steering wheel specifically when the front wheels go over bumps, road joints, or uneven surfaces
  • It has been getting progressively worse
  • It is noticeable at low speeds and worsens over bumps
  • It is not speed-dependent (not a high-speed motorway shimmy)
  • Turning off all driving aids (lane keep, cruise, speed limiter, parking assist) makes no difference – vibration remains identical
What has already been done:
  • New tyres fitted
  • Wheel balancing done (additional weights added, but this seemed to make it slightly worse)
  • Full suspension and steering inspection by workshop – no mechanical faults found
Fault codes present:
  • U045A00 – Implausible data received from Parktronic
  • U11A600 – Communication with radar sensor has a fault
Workshop's current theory:
The workshop believes it is either transmission-related or caused by the PARKTRONIC/RADAR system. They have cleared the car mechanically of any suspension or steering faults.
My concern:
The vibration is bump-triggered and feels mechanical rather than electronics-related. I have disabled all ADAS systems and the issue persists unchanged. Online research and forums consistently point to front suspension components as the likely cause for this specific symptom pattern.
Components I suspect may not have been checked under load:
  • Control arm bushings
  • Ball joints
  • Tie rod ends / track rods
  • Sway bar links
  • Strut top mounts
  • Shock absorbers / dampers
  • Steering rack mounts
  • Wheel runout
Questions for the forum:
  1. Has anyone experienced a similar bump-triggered steering vibration on W177 or W247 that turned out to be a specific component?
  2. Could U045A00 or U11A600 realistically cause a mechanical-feeling bump vibration?
  3. Could transmission mounts cause vibration that is specifically triggered only by bumps?
  4. Any recommended diagnostic steps or components to check that are commonly missed on a W177/W247 front-end inspection?
Any advice or shared experience greatly appreciated. Happy to provide more detail if needed
Reply 0
Subscribe
Currently Active Users (1)
