B-Class (W245) Discuss the new B-Class MPV: B200 Turbo, B200 CDI, B180 CDI, B150, B170, B200
2006 B200 Turbo
Old 02-20-2017, 01:52 AM
BMD19's Avatar
Mercedes Benz B200 Turbo (W245)
2006 B200 Turbo
Hi,
I have a 2006 B200 Turbo, starting fine, but Turbo kicks in sometimes and then does not work, If I turn ignition off and then on, the turbo comes back, but then off again after a while, when the Turbo is running, the car is quick, so I do not think it is damaged, is there a relay that could be the issue or plugs that might affect how the turbo or management systems is working?
Old 02-20-2017, 09:49 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to W245 forum...
Old 02-27-2017, 07:54 AM
Cosworth2000's Avatar
2016 C450 AMG / C50 Lorinser
Does any CE come up? If so, read the code. You may have a problem with a vaccum hose that controls the wastegate. If there is a problem with the wastegate, you will need a new turbo which will be costly since the work to remove it take times.
