B-Class (W245) Discuss the new B-Class MPV: B200 Turbo, B200 CDI, B180 CDI, B150, B170, B200
B150 w245 MAF location
Old Jan 11, 2020 | 07:51 AM
Raj Tailor's Avatar
w245
Arrow B150 w245 MAF location
Hi All,
Getting diag code P068. This i'm told could be one of two faults with the MAP and or MAF sensor.
The MAP sensor i've found ok, but am confused about the MAF sensor location. is it the one just downstream of the throttle butterfly?
I've read that this is called the inlet temp sensor. is this the same as the MAF, if not where do i find the MAF (with pics preferably.)??
Old Feb 4, 2023 | 03:44 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Did you find it? I cant find the MAF on my daughter's B180. Any clues appreciated
Old Dec 26, 2024 | 08:53 AM
SMOKEZILLA's Avatar
Yes it is called air intake temp sensor, m276 doesn’t have a MAF LIKE THA OTHER MOTOR
Originally Posted by Raj Tailor
Hi All,
This is it…..
This is it…..
Old Dec 26, 2024 | 02:33 PM
BlackML550's Avatar
Yes that is the MAF sensor. It is confusing and I encountered thr same question when trying to find it.
