- Mercedes-Benz C-Class AMG: Air intake Reviews
Reviews and comparisons of top products
Browse all: Air Intake and Exhaust Guides
Burger Motorsports Intake Came out!
But i will probably change the intake too. To many bends.
Installed it straight away, was not sure how coz didn't find the manual on the website/in the box. Since I had experience setting up Race Chip Pro, everything came out to be very easy. 3 screws out, 3 crews in. As well as the others I spent some time connecting parts, it was easier on hot engine, but had to wear gloves.
The sound is as shown in the video, even sexier when you hear it live - like it a lot. Will see if there is any power increase, have to run some tests with Dynolicious app.
These are all details we need to know...
I did though have the "3 prong" friction connector upside-down when I tried to start the car (the connector that's in the MIDDLE of the jb+ harness). Car would crank and turn off a second later. Did this about three times before finding out that it was upside-down. After putting it in correct position car cranked successfully but now has check engine light. So come to think of it, I'm sure this is why I'm getting check engine. Should I disconnect negative terminal on battery?
Where is the negative terminal to the battery located (top left engine bay?)? I want to try to disconnect that first to see if it gets rid of the light.
Hmmmm years of building turbo 4 bangers and not once did something like that never happened.
Turned on car this morning and car was running fine until I hopped on the freeway and accelerated moderately hard (4500-5000rpm) to 75-80mph. After that the car felt like it lost all acceleration power (limp mode?). I would floor it all the way and the car would not accelerate. RPM's would go up to 3-4k but it was taking forever to get up to speed, like I was towing something heavy.
No CEL light came on.
After getting off the freeway 30 miles later, I turned off the car then back on again and suddenly everything was back to normal. Anyone experience this issue? I think it was the hard acceleration that brought it to limp mode.
Again this is with intake and jb tune at stock settings.
When I first got the tune, the limp mode would happen to me everytime I went WOT. Now, after driving hard in "S" mode for a while, the overboost CEL does not come on and I haven't hit limp mode for about a month now 1/2 now.
As for the CEL, it happens when you get the overboost "limp mode" reccuringly or "bad enough". I just got a code scanner to manually reset it, but apparently it goes away by itself too.
I have never got the Overboost limp mode on teh stock settings, only when I turned it up... I also agree that it takes a while for the car to get used to the extra power I think. I find that driving it hard without WOT will make you go into over boost mode sooner/more frequently.
Loving the tune and intake so far though. No longer struggles turning up into a hill and throttle response is better. Blow off (?) sounds great.
i was probably one of the first to get the intake and a tip for install.. heat up your stock pipe with a blow dryer or you'll have a **** time fitting it in.
only reason i got the intake was for the sound.. it sounds fukin amazing.. every time you let go of the throttle you get a nice hiss.. nothing as loud as my evo's blow off but definitely a turbo air dump.. had a many people turn heads on street and probably go wtf is that a turbo c class? lol
and please don't call it blow off sound because it's not.. most turbo cars with a cone filter have this sound.. like audis and the new bmw 4 banger.. you were just never able to hear it before because the filter was in a box..
try driving the car with out a filter at all.. just open intake pipe.. that'll really blow your mind
