has anyone added wheel spacers to the rear of their coupe w/ stock wheels?
Old 05-18-2012, 06:32 AM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
Question has anyone added wheel spacers to the rear of their coupe w/ stock wheels?
i am looking to add spacers to just the rear of the c coupe… the car has the 18" amg double spoke wheels.
reasoning… when i look down the side of the car the rear wheels seem to be a bit more recessed (pushed in) than the front wheels... i prefer a more aggressive stance and at bare minimum aligning the front and rear wheels with one another... pushing the wheel out closer to the edge of the rear quarter… i'm not looking for them to even be close to outside the lip.
has anyone done this as of yet with the stock 18” rims and if so... what size spacer and size did one use? 10mm, 12mm or 15mm? and what name brand? eibach, h&r, or a universal brand sold on ebay? i will only purchase a hub centric set up and also prefer the longer lugs to match the factory type for aesthetic purposes.
thank in advance for your input.
Old 05-18-2012, 06:56 AM
i found a set of h&r trak+ spacers but need to determine what size to give the car the right look (10, 12, 15 mm)?
hoping someone has some pictures to post before & after... for i don't take delivery of the car until months end...
http://www.ebay.com/itm/H-R-12mm-DR-...sories&vxp=mtr
Old 05-18-2012, 07:01 AM
~ one of my prior cars... with and without spacers (to show what i'm trying to accomplish):
without spacers:
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-xfirerear1-2.jpg
with spacers:
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-img_08311-1.jpg
Old 05-18-2012, 10:42 PM
~ i went ahead and ordered 10mm h&r trak spacers (front & rear)... as well as extended lug bolts... hoping it looks good.
http://www.ebay.com/itm/190562020020...84.m1497.l2649
Old 05-21-2012, 02:40 PM
Showa's Avatar
99' Lexus RX300-retired, 01' BMW 330i
I am sure there won’t be any rubbing at all with the 10mm spacer. And it will look very cool.
Old 06-08-2012, 08:32 AM
Thumbs up
~ i purchased the 10mm spacers for the coupe... i hope to install them tonight and determine if the spacing is right.
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-spacers.jpg
Old 06-09-2012, 07:27 PM
before:
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-2012-06-08183033.jpg
after:
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-2012-06-08183045.jpg
10mm front and rear in pics ... thoughts? (i may have to run a smaller 5mm in the front).
Old 06-14-2012, 04:25 AM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
dont spacers make your cars rub against the wheel fender?
I also have the 18" amgs and I just dropped my car on super sports and I want my rears flush out more... but i am just scared even 5mm will make it hit the outside fender over bumps... anyone worried about that?
Old 06-14-2012, 05:57 AM
~ no rubbing (edge) what-so-ever with stock height. i am planning on lowering my car too and don't expect any rubbing.
i have ran spacers on many of my cars without concern or issues... just improved looks.
Old 06-14-2012, 03:36 PM
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
looks good. I don't know if it's from the pictures, but I think the fronts look fine. However, it looks like you could also have done 15mm spacers on the rear.
Old 06-14-2012, 08:55 PM
LandSeaAir's Avatar
2008 W204
Would you ever considering running spacers on the front? or is it a look meant for the rear.
Old 06-24-2012, 08:42 AM
~ i have finally finished toying around with sizes and found the correct spacers for the perfect stance & spacing ...
5mm front & 10mm rear are the set up (see pics)...
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-2012-06-23182645.jpg
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-2012-06-23182615.jpg
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-2012-06-23182620.jpg
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-2012-06-23182627.jpg
the end result provides a more bold & muscular stance... lowering springs (when available)... will complete the look.
Old 06-24-2012, 11:33 PM
Kanobikkdd's Avatar
2012 C-Coupe
love your car
i pretty much like the spacers but is there a DIY in that package?? if not, can you put either here or in the DIY thread? that would be helpful for all of us...
Old 07-17-2012, 07:14 AM
~ the process is quite easy... remove the wheels, place the spacer on the hub and reinstall wheels using longer lug bolts.
hope this helps.
Old 08-06-2012, 07:52 AM
i have a brand new set of 10mm h&r trak spacers for sale (still in the box) if anyone is interested. feel free to pm me.
Old 08-06-2012, 01:12 PM
2012 C250 Coupe's Avatar
2012 C250 Coupe
How much for the spacers? I think I am going to leave the stock wheels, defintely for at least the upcoming winter. But would think about putting the spacers on. I like the look of yours and our cars are so similar.
Still wish the orange reflector on the bumper was the same color white!
Old 12-18-2012, 10:57 PM
AllEyesOnMe's Avatar
C Coupe
Bump,
Has anyone tried going with an even more aggressive wheel spaers (25mm or 30mm) on stock wheels and stock height? Even with 10 mm spacers, the wheels still look tucked in - I honestly don't see much difference at all from the pictures.
Perhaps a more wheel spacer that'll make the wheel sit flush with the rear fenders would be ideal.. But would there be rubbing?
Old 12-25-2012, 10:30 AM
if your going with the 5mm spacer ... they are disc/hub centric but not hub centric to the rims. in order to get things lined up and balanced... i used some super glue to hold the spacer to the back of the rim (lining it up to the holes before setting in place). then the challenge is holding the rim in place to eyeball the centering and tighten the bolts at the same time. not easy to get it right. well i found the solution via my local mb parts manager...
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-guiderodpin_zps4a8c1ca3.jpg
i purchased 3 of these 5" long pins to assure perfect alignment. screw 3 in...finger tight... slide the wheel over the rods and install two bolts, removing a rod at a time and install the rest of the bolts for a perfect alignment.
Old 01-03-2013, 03:30 PM
RZ-JEDI's Avatar
2013 C250 COUPE
what's the part number for the pins?
Attached Thumbnails has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-guiderodpin_zps4a8c1ca3.jpg
Old 01-03-2013, 05:40 PM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
Hey Andrew (Op) I wrote you in the other thread with your car pics !
Old 01-29-2013, 09:25 PM
~ the part number is A 204 581 00 74
Old 02-07-2013, 09:07 PM
~ here are some pics of how the pins work:
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-img_1024_zps8cf568de.jpg
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-img_1026_zps0d60475c.jpg
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-img_1031_zps2265518f.jpg
has anyone added wheel spacers to the rear of their coupe w/ stock wheels?-img_1032_zpsd6edd261.jpg
Old 05-21-2013, 12:19 PM
dbfenton's Avatar
2013 MB C350 Coupe, 2006 Toyoya 4 Runner, Cessna A152 Aerobat, Cessna 172N / 180 HP
C Coupe spacers
Hi Andrew,
Love the look of your Coupe.
I have a 2013 C350 Coupe Polar White / Almond Beige w/18'' AMG option wheels like yours.
I'm thinking of staying with 18 inchers but have been looking for "Chrome Mesh style Wheels". I NEED CHROME.
Do you know the "offset" of the 18" AMG wheels & the wheel width F&R ?
What offset would you recommend to get the same look if I were to find some new wheels and not use spacers?
Thanks for the "Tech Tip" on the alignment studs.
Don
Old 06-06-2013, 01:21 PM
MFDONTRON's Avatar
2013 GLK 350 4matic
Awesome thread. Awesome ride, was thinking of doing 5mm myself but I've seen people run 10mm/12mm front/rear
Old 04-07-2016, 12:15 PM
dCLA503's Avatar
2014 CLA250
Spacer
hey andrew - the car looks really good!
I am planning to add spacers to my CLA250 as well. but thinking 15mm in the back and 10mm in the front and I will be riding on stock height, not looking to mess with the suspension. Not sure what kind of extension lugs I would need. Seem like you did yours and hoping to get some advices/suggestions from you.
Please let me know your thoughts. Thank you!
Quick Reply: has anyone added wheel spacers to the rear of their coupe w/ stock wheels?
