has anyone with a c250 coupe replaced their exhaust with a stock c300 or c350 dual?
Subscribe
Jun 13, 2012 | 09:11 PM
is this a direct bolt on? and will turbo back pressure be a problem? and will i lose power?
i prefer the symmetric look of a dual muffler system and like the stock look. i also understand i need to change the valance as well to accommodate the dual pipes.
thanks in advance for any input.
Reply 0
Oct 15, 2012 | 08:24 AM
bump
Reply 0
Oct 15, 2012 | 09:04 AM
You might be the first to do it. Let the other 250 ers know when you are done
Reply 0
Oct 15, 2012 | 09:28 AM
Putting $1000 plus trying to make a 250 look like something its not is a waste and will probably make your car slower than it already is. Whats next some phony AMG badges? You should have put that money toward a real 350.
Reply 0
Oct 15, 2012 | 09:41 AM
Quote: Putting $1000 plus trying to make a 250 look like something its not is a waste and will probably make your car slower than it already is. Whats next some phony AMG badges? You should have put that money toward a real 350.
~ wow a smart *** peanut gallery comment...you guys are on fire this morning...perhaps you should try out for last comic standing.
it's called balance jack ***...nothing to do with a wanna be.
Reply 0
Oct 15, 2012 | 12:22 PM
come on man, thats just being a d!ck. share your ideas and opinions IF you have something positive to type.
lets just chalk this up as you being "new:
i have no idea if one can put a C300/350 exhaust on.
Reply 0
Oct 15, 2012 | 07:21 PM
Quote: is this a direct bolt on? and will turbo back pressure be a problem? and will i lose power?
Symmetrical look does look decent. It's something I would consider (C350 look).
Try and get some baseline dyno numbers before and then one after. You can be the guinea pig
Reply 0
Oct 15, 2012 | 07:48 PM
Nope, will not be able to be plug and play for the simple fact that we only have 1 cat and 1 exhaust run from the engine. The OEM C300/C350 exhaust has two cats and a dual in/dual out resonator. You're better off doing what I did with quad exhaust - you can find it on a quick search, but just get a C350 diffuser and only do dual exhaust tips. There is actually a recent thread about Dual exhaust on the C250 a bit further down. I posted pictures of my setup and how you could convert it into a dual exhaust setup.
Reply 0
Explore
Oct 15, 2012 | 09:05 PM
Quote: Nope, will not be able to be plug and play for the simple fact that we only have 1 cat and 1 exhaust run from the engine. The OEM C300/C350 exhaust has two cats and a dual in/dual out resonator. You're better off doing what I did with quad exhaust - you can find it on a quick search, but just get a C350 diffuser and only do dual exhaust tips. There is actually a recent thread about Dual exhaust on the C250 a bit further down. I posted pictures of my setup and how you could convert it into a dual exhaust setup.
~ thanks for your insight and experience feedback. i will take a closer look at your setup... cheers!
Reply 0
Oct 15, 2012 | 09:56 PM
It's all about trying to achieve a symmetrical look with either a C180 or C250 which unfortunately are equipped with only one tip, I'm sure even you can relate to that.
I can agree with 'one point' about what your saying ie. I too do not want to simulate or look like another variant whilst trying to achieve that balanced look we're on about hence the struggle to find something appropriate.
Cost of the vehicle should not even come into it as in different markets it varies considerably, here in Australia these vehicles cost 2 to 3 times what you pay in the U.S so for some a C350 may not be an affordable option over a C180 or C250.
O.T. Hate to rain on your personal choice but in my own personal case regardless of cost I chose the C250CDI over every other variant as the preferred optimum daily driver choice, sorry but IMHO the C350CGI Coupe didn't even compare in this regard pity about the single tail tip, but I'll fix that eventually
Reply 0
Oct 15, 2012 | 09:59 PM
Anyone else seen this
Reply 0
Oct 15, 2012 | 10:01 PM
Quote: ~ thanks for your insight and experience feedback. i will take a closer look at your setup... cheers!
Was going to say, there's already another thread on this same topic andrew - I'm currently looking into some of those options mentioned there
Reply 0
Oct 15, 2012 | 10:02 PM
Quote: Anyone else seen this
Pics not working for me
Reply 0
Subscribe
Currently Active Users (1)
