~ new wheels for my c coupe... 19's
Old Aug 16, 2012 | 11:37 AM
Ubiquitous5's Avatar
C350
Wheels look great. All you need is a drop.
For those who are wondering, If you're going to run wide tires between 255 to 275, with a drop, I would go with the highest offset possible (no spacers required).
Mercedes offsets are really conservative. I'm running 255 35 19 (9.5 Width Wheel) with a 1 inch drop and its rubbing a little bit =/
It barely sticks out. Currently looking to trade my rear tires with someone with a 245 35 19 lol.
Old Aug 16, 2012 | 02:04 PM
dayjob3's Avatar
E53 AMG Cabriolet
What offsets are you running?
Old Aug 16, 2012 | 02:28 PM
C350
+40 F, +45 R
I have a one finger gap in the rear w my BBS Wheels.
Old Aug 16, 2012 | 10:17 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
Thumbs up
~ finally my wait is over ... they have arrived via fedex directly from germany today...
to be installed a week from today... more pics to follow once the package is complete.
Old Aug 16, 2012 | 10:31 PM
Thumbs up
Originally Posted by dayjob3
Are you happy with the Offsets? or do you think ET55 would have been better for the rear? I would like to know if the wheels will tuck in under the fenders once its lowered.
~ i think the et50 rears look great without lowering the car... and i still think i'll be ok once lowered an 1" with a bit of negative cambered dialed in via the alignment... all to be determined - in a week once the eibach's are installed and the alignment is complete.
but to further answer your question... a et55 rear offset would be a safer set up (if a set can be found) if one's lowering the car and hauls a full load of occupants.
Old Aug 22, 2012 | 08:55 PM
well i had the eibach pro-kit springs installed today...
i love the drop on the front but the rear seems to have very little change? do you think it will settle?
(specs were to be 1.1" front & 1.0" rear) ... thoughts?
Old Aug 23, 2012 | 01:02 AM
  #32
skat004's Avatar
C-Class Coupe 2012
I installed H&R springs on my 350Z years ago and had the same issue (rear was much higher). It settled a little after about 3 weeks. However, even after 2 years of having the springs installed, the rear gap was always greater than the front.
I wonder if they design them to be that way? Perhaps accounting for the fact that you may load heavy luggage in the boot and the springs wouldn't have much room for movement if they were even with the fronts to start off with?
Old Aug 23, 2012 | 01:31 AM
  #33
Showa's Avatar
99' Lexus RX300-retired, 01' BMW 330i
I have Eibach pro-kit springs in my E46 and the rear always looks higher in my taste. It would not settle in my case.
But I do think the drop looks perfect on your C-coupe.
Questions
1). What is the measurement of the front wheel gap (stock is about 1.75 inch)?
2). What is the measurement of the rear wheel gap (stock is about 1 inch)?
Old Aug 23, 2012 | 03:21 AM
  #34
AV1's Avatar
AV1
C204 C250-CDI
Nice, I like it !!!
Curious also as to why the rear is a little higher than what you would expect, but I'm sure Eibach know what they're doing - must be like that for a reason.
I've always used Eibach springs for decades on many of my past and present cars without any operability issues.
Old Aug 23, 2012 | 07:43 AM
  #35
Originally Posted by Showa
But I do think the drop looks perfect in your C-coupe .
Questions
~ the lowered heights are as follows: front is .75" & rear is 1.25".
i think i will try to visit the installation company today and see if they can confirm the spring is seated/turned correctly at the top and bottom at the pad and perch. if so, and the height is as eibach intended... i may have them trim 1/2 of the dead coil in the rear to adjust the height and have things more uniform/balanced.
Old Aug 23, 2012 | 12:01 PM
  #36
dayjob3's Avatar
E53 AMG Cabriolet
Installed H & R Super Sports1.7 front 1.8 back made for W204 on my coupe yesterday. Took a gamble but they fit perfect. Ride is noticeably stiffer but a good feeling since steering was a little lose.
Old Aug 23, 2012 | 03:43 PM
  #37
dayjob3's Avatar
E53 AMG Cabriolet
Need to fill in those lonely wheel arches now.
Link to B4 n Aft H&R SS Drop.
https://picasaweb.google.com/1098767...eat=directlink
Old Aug 23, 2012 | 08:51 PM
  #38
~ i ordered 9mm rear spring pads (stock are 17mm on the coupe) ... this will lower it the difference i am looking for...
now with the revised pads ... this lowered it the difference i am looking for... perfect now.
Old Aug 25, 2012 | 04:34 AM
  #39
mikess2k's Avatar
2013 C350
car looks great man!
Old Aug 25, 2012 | 11:38 PM
  #40
C350
Drop makes a huge difference. Good job and great choice of wheels. Very OEM+
Old Sep 2, 2012 | 10:09 PM
  #41
t-wd.net's Avatar
All sorts of cars
Looks fantastic! Thanks for the info re springs & spring pads too, Andrew.
Old Sep 19, 2012 | 06:02 PM
  #42
dayjob3's Avatar
E53 AMG Cabriolet
I ordered the Rohana RC5's and tires with the same dimensions as yours. Pics in my post above. [Front 8.5 et45 245/35/19 Rear 9.5 et50 275/30/19]. Because my coupe is dropped fractions of an inch more than yours, I am wondering if I will clear inside and out. Do you rub at all?
Attached Thumbnails ~ new wheels for my c coupe... 19's-rohana-wheels-rohana-rc5-wheels-matte-black-concave.jpg
Old Sep 19, 2012 | 06:37 PM
  #43
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You can always install a shorter spring pad to get a lower look in the back
Old Sep 19, 2012 | 07:12 PM
  #44
JohnnyUte's Avatar
C350 4matic coupe
I ordered the Rohana RC5's and tires with the same dementions as your set up. [Front 8.5 et45 245/35/19 Rear 9.5 et50 275/30/19]. Because my coupe is dropped fractions of an inch more than yours, I am woundering if I will clear inside and out. Do you rub at all?
Those wheels look great. Please post pics when you get them.
Old Sep 20, 2012 | 08:31 AM
  #45
I ordered the Rohana RC5's and tires with the same dementions as your set up. [Front 8.5 et45 245/35/19 Rear 9.5 et50 275/30/19]. Because my coupe is dropped fractions of an inch more than yours, I am wondering if I will clear inside and out. Do you rub at all?
~ i have no rubbing issue at all...even with 200 lbs of added weight in the trunk for a short trip.
Old Sep 22, 2012 | 01:20 AM
  #46
C3FiddyC's Avatar
2012 C350 Coupe
great set up!
Old Sep 22, 2012 | 07:57 AM
  #47
~ you're welcome... i am thinking of switching the rear spring pad out again with the 5mm pad to lower the rear a bit more. still sits up a tad too much.
Old Sep 24, 2012 | 10:30 PM
  #48
~ here are some additional pics with about 200 lbs of cargo in the trunk...
i am planning on changing the spring pads this week ...the adjustments will make this the standard lowered stance in the rear... your thoughts?
Old Sep 24, 2012 | 11:19 PM
  #49
AV1's Avatar
AV1
C204 C250-CDI
My thoughts, nice, nice and very nice !!!
Proposed finished rear height looks the goods
Old Sep 24, 2012 | 11:22 PM
  #50
t-wd.net's Avatar
All sorts of cars
+ 100
Couldn't agree more. The car looks AWESOME!
