some new pics with the 19" ...
Old Mar 19, 2013 | 05:22 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
~ some new pics with the 19" silver painted in lay rims with the machined wheel face:
Old Mar 19, 2013 | 09:37 PM
AV1's Avatar
AV1
C204 C250-CDI
Nice, Nice, Nice !!!
Much better than before andrew
As mentioned a while ago because that model of rim is no longer available and with the custom finish you've applied I'll happily take them once your lease is up
Old Mar 20, 2013 | 11:18 AM
Cyber GS's Avatar
2013 CTS-V, 2017 Audi Q7 / Past MB's: 2011 ML350 & 2012 ML350
Looks really good!!
Old Mar 20, 2013 | 05:35 PM
Showa's Avatar
99' Lexus RX300-retired, 01' BMW 330i
It looks just.....perfect. Can't find other words to describe it.
Old Jun 29, 2013 | 08:59 PM
elvis0502's Avatar
c350 coupe
Can you show the detail of your tire with this 19'' rims. And if you change your diameter how to correct your speedo, thank you!!!!!!!!!
Old Jun 30, 2013 | 12:43 AM
JohnnyUte's Avatar
C350 4matic coupe
If you size them right with 19s, you really won't have a change with the speedo. I got smaller sidewall tires and they're almost identical (about .25" at the very most) in diameter to my stock 18s.
Old Jul 1, 2013 | 08:19 PM
elvis0502's Avatar
c350 coupe
What size tire you used??? Can you tell me?? Thank you
Old Jul 1, 2013 | 08:30 PM
JohnnyUte's Avatar
C350 4matic coupe
I'm running: F 225/35-19, R 265/30-19. There's a little stretch with those sizes, but being a 4Matic and not being able to lower I wanted something that matches the stock size as close as possible. Plus, I wanted the diameters to be as close as possible. Honestly, I love the look and stance now, couldn't be happier. I think these cars look best with 19s.
Old Jul 1, 2013 | 08:40 PM
elvis0502's Avatar
c350 coupe
Yes, I like your car with this rim. So I will try your way to change my rims.
Old Jul 1, 2013 | 08:41 PM
elvis0502's Avatar
c350 coupe
What about the feeling? Bump? or as comfortable as original???
Old Jul 1, 2013 | 09:41 PM
dbfenton's Avatar
2013 MB C350 Coupe, 2006 Toyoya 4 Runner, Cessna A152 Aerobat, Cessna 172N / 180 HP
Wheel Dilemma
Andrew, your coupe looks great, I liked it with the 18" wheels also.
Maybe you could school me on wheel off set, width & looks.
I have a 2013 C350 Coupe, Polar White / Almond Beige w/ AMG 18" 5 spoke wheels. I'm planning on staying with the 18".
I've looked at all the wheels on "Wheelplus" & others sites and can't find the proper offsets ( 50 & 54).
How would ET45's fit, look & any rubbing issues ?
Has anyone tried "wheel adapters or spacers" to change the bolt pattern giving a larger selection?
It's hard to imagine the limited selection available for MB's.
Don
Old Jul 1, 2013 | 10:10 PM
JohnnyUte's Avatar
C350 4matic coupe
It's hard to tell, I was out of town for a month and put the wheels on as soon as I got back. The ride won't be as comfortable as before due to a lower sidewall height, but it's still very smooth and straight.
Old Jul 1, 2013 | 10:32 PM
elvis0502's Avatar
c350 coupe
Thank you for your help!!!!!!!
Old Jul 5, 2013 | 09:40 PM
dbfenton's Avatar
andrew c coupe
I believe you originally had 18” wheels with 5mm spacers - front & 10mm spacers – rear? Did you use the spacers with the 19” wheels?
I’m having trouble finding ET50 front & ET 54 rear wheels.
Please correct me if I’m wrong but adding spacers does not change the “offset” or the “back space” but moves the wheel “outboard” ?
So by using a spacer I might be able to compensate somewhat for the incorrect “offset”?
Don
Old Jul 6, 2013 | 10:22 AM
JohnnyUte's Avatar
C350 4matic coupe
Yes and no, the spacers move the wheel outboard more which in a way decreases the offset. It can get tricky conceptually but if you think about it at the most basic level, you have it, it just pushes the wheel out.
Old Jul 10, 2013 | 11:13 AM
~ agreed and thanks for answering the question.
Old Jul 15, 2013 | 02:40 PM
gavrocool's Avatar
e350 coupe
Nice clean look.
