Battery Draining Mystery
Old Aug 24, 2013 | 03:40 AM
HF030's Avatar
C350
Hello,
I've encountered a problem that until now no one seems to know the answer to:
The other week i went to my car and the battery was suddenly completely dead for no apparent reason. The car hasn't been standing for more than a day. MB came around and towed it. They replaced the battery with the claim that the old one was totally busted and wouldn't even hold a charge. I got the car back and for 2-3 days everything was fine when suddenly I had the same exact problem, except this time the SRS system (in charge of seatbelts and airbags) showed me an error as well. MB picked it up again but I haven't heard back yet.
Has anyone had a similar problem or could know what's wrong
Old Aug 24, 2013 | 11:50 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Originally Posted by HF030
Hello,
My guess is that you my have a defect control module that is slowly draining the battery. Unfortunately, they are many control modules, and the techs at the shop will have to perform tests to find the culprit
Old Aug 29, 2013 | 09:33 PM
Vulcaneer's Avatar
C300 4MATIC And formerly 73 450SL
They will likely hook up a DMM to the pos side of the battery in series. Then start pulling fuses. When the DMM shows a loss of amperage draw they have found the bad circuit. Then they will change parts until the bad component is found.
Hope it is under warranty.
