C230 Kompressor Coupe Catalytic Converter
Old Aug 29, 2013 | 09:48 PM
Vplume's Avatar
C230 Kompressor
Hi guys,
Brand new to the forum, here to hopefully find out some information so that I can fix an issue with my car. I drive a C230 Kompressor Coupe that shakes violently when put into drive/reverse from cold start. (It's an automatic) when it warms up it's fine- but with cold weather, it will stall out completely when put into gear. I brought it into the shop 3 times regarding this issue and they just can't seem to figure it out, however have determined the tapping loud noise to be the catalytic converter. Although it is not broken- it's very much louder than it should be- and Im wondering if this could be the issue I am facing. The vehicle has low Kilometers, and I am the second owner. Could it pertain to the fuel used? I haven't had the vehicle for long- I only use premium gas, but I'm wondering if the previous owner may have used regular.. Could this be a scenario in which could affect the converter?
Thanks for your responses and help
Old Aug 30, 2013 | 10:16 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
You didn't mention the year of your car but it sounds like you need to be in the W203 Section.
https://mbworld.org/forums/c-class-w203-3/
