Overhead Lighting Control Repair help needed
Whilst fumbling for the driver side convenience light switch in the overhead panel, i punched in a small plastic square-plug. It clearly is designed to be snapped in' I'd like to get this back into place but i can't figure out a way to have the overhead light control panel drop from the ceiling.
Ideas?
UPDATE- The lighting panel has a faux-grille made of plastic that is secured at the two ends. I was able to get the larger end (toward the rear seat) loose but I see that the end near the windscreen is somehow captured at each of the two reading light switches. I see that there is a circuit board behind the faux-grille and that may be my next obstacle. But if I get could get an idea how to remove this faux-grille from someone who's done it, that would be a big step forward.
Thanks again.
