Wheels for C350 coupe
Old Jan 23, 2014 | 12:33 PM
r2racer64zl's Avatar
C350 coupe 2012
Hi all,
Would 19" wheels offset is 35 5-112 fit a C350 Coupe 2012? If not, why?
Thanks,
Old Jan 23, 2014 | 09:50 PM
AV1's Avatar
AV1
C204 C250-CDI
To achieve a nice fit with zero probs ET or offset of 35 is no good for our cars, the wheels will stick or poke out the guards for comparison the ET on all OEM wheels for our cars are 50 and above, going down to 45 still works well.
It all depends on the end result you specifically want, some people like that set up of a widened wheel base and do go for low offsets.
Old Jan 24, 2014 | 12:27 PM
C350 coupe 2012
thanks for the reply. I will go and buy the wheels and add 10mm spacers to the wheels.
Thanks,
Old Jan 24, 2014 | 06:30 PM
AV1's Avatar
AV1
C204 C250-CDI
Thanks,
AFAIK a 10mm spacer will further push the wheels out ie. will be similar to the
Wheels being ET25.
However please check all of that with your wheel provider to make sure.
