So who else has the Burger Tuning intake and tuner installed?
Old Feb 10, 2014 | 05:51 AM
djprov431's Avatar
2021 C63S Coupe
I just ordered the intake and tuner from
http://burgertuning.com/mercedes_benz_products.html
for my 2014 C250 sport - anyone else running it?
Tips, tricks, info I need to know?
Thanks in advance!
Old Feb 11, 2014 | 05:32 AM
djprov431's Avatar
2021 C63S Coupe
Seriously? No one?
Old Feb 11, 2014 | 09:09 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
You will definitely see a big difference in performance. I recommend using some large diameter shrink tubing or electrical tape to cover the one plug that does not have a retaining clip.
Old Feb 11, 2014 | 11:36 AM
djprov431's Avatar
2021 C63S Coupe
So you have it and think it performs as advertised - no ill effects?
Do you also have the intake?
Tracking says it should be at my door soon - should have it installed over the weekend!
Old Feb 22, 2014 | 05:06 AM
OCtheMIKE's Avatar
2012 C250 coupe
Put some foam or felt down on the metal edge under the intake because it rubs and can wear a hole into the filter surface. Also, don't turn up the tuner too high or your car will go into limp mode. If it does just restart the engine.
I see good performance with my car having both installed. Satisfied with making the purchase. I've had it installed for a year now and haven't seen any negative effects.
Old Feb 22, 2014 | 03:42 PM
djprov431's Avatar
2021 C63S Coupe
I think there must be a notable difference between the 2012 and 2014 ECU programming - my car doesn't like the tuner but I'm working on it...time will tell.
Thanks for the tip on the air filter - I ran my hand under it and didn't feel any sharp edges but I'll take the cone off and have a look anyway.
Old Mar 7, 2014 | 06:55 PM
casper721's Avatar
2013 C250 Coupe
If you do more research on the forum, you'll see that the majority of us had problems with the intake because after a while, there will be a punctured hole on the air filter. Simple fix is to get the K&N filter.
Otherwise, intake is good to go.
Old Mar 8, 2014 | 11:43 AM
E350 Sport/ML350RWD
If installed properly- there will not be a rubbing issue. I had issues with my BMS JB+ and have questioned them on two occasions. They said the Sport PLUS package would not make a difference, but I don't understand this since it includes:
1. Sports exhaust system
2. Engine management with more responsive accelerator mapping
3. More sporty transmission configuration in S and M mode, with shorter shift times, double-declutch function and active downshift when braking.
They told me to send it in for evaluation.
Old Mar 8, 2014 | 02:22 PM
greasykid's Avatar
2015, ML250 BlueTEC
Burger Tuning
Have 2013 C250 COUPE. Any diff in ECU tuning? Like to hear from anybody who has installed BT on 2013 C250. Any improvements,mileage etc.
Old Mar 8, 2014 | 08:17 PM
E350 Sport/ML350RWD
A standard C250 or a C250 W/Sports PLUS package?
Old Mar 9, 2014 | 07:03 PM
greasykid's Avatar
2015, ML250 BlueTEC
Whick 250?
Your every day C250 COUPE.
Old Mar 9, 2014 | 07:04 PM
greasykid's Avatar
2015, ML250 BlueTEC
Which 250?
Your everyday C250 COUPE
Old Mar 10, 2014 | 07:39 AM
djprov431's Avatar
2021 C63S Coupe
Read this thread:
https://mbworld.org/forums/c-class-c...ted-tuned.html
Old Mar 19, 2014 | 08:53 AM
Eric.i.gonzalez's Avatar
2013 C350 4matic Coupe
2013 C350
Does anyone have some good leads on going FI on a C350 coupe?
