Jack Stands... anyone used them
Old May 15, 2014 | 02:01 PM
chatham's Avatar
c250
i am abut to do an oil change and need to get under the car. I searched but didn't find anything on using jack stands under the car. anyone seen on how/where to place jack stands? don't want to damage the underside.
thanks
Old May 16, 2014 | 10:26 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
On ebay, I bought a set of jackstands that have the rectangular blocks attached that fit in the recess points under the car. They are a high quality product and they work great. I am away from home now, so I don't have the company name or part number on hand though
Old May 16, 2014 | 11:37 AM
chatham's Avatar
c250
I will look for them and if you find the info please forward. where did you jack up the car to put the stands under the car? did you use a floor jack?
Old May 16, 2014 | 04:18 PM
capt_paul's Avatar
There is a rubber jack pad on the front cross member....you will see it on the cutout of the underpan. For the rear, I just place the jack under the rear differential.
I use a low-profile aluminum floor jack that I purchased from Harbor Freight Tools.
For an oil change, you may want to use an oil extractor that sucks oil from the dipstick tube, then you will not have to jack up the car to service the oil, and the oil filter is serviced from the top as well.
