C350 Reliability / Major Issues?
Old Jan 18, 2015 | 12:56 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Hi all,
Prospective C350 Coupe buyer here. My wife is interested in the car and I think it'll be a nice highway cruiser for us. Everything I've read (and searched on this forum) points to a few reliability concerns with the C250, but not much about the C350. Any major issues or concerns? Recalls? I'm fine with the annual maintenance costs, just don't want to be surprised with major repair bills out of warranty. I've had german cars for years now and am very **** about preventative maintenance; despite that I had an '02 BMW X5 that nearly bankrupted me (every leak cost me $4k). Then again I now have a 1999 M Roadster which extremely reliable and affordable. Seems like the C350 will be more of the latter.
Thanks,
Cyrus
Old Jan 19, 2015 | 08:38 AM
Nickanna's Avatar
C63 Coupe
Hello and welcome!
I haven't had mine as long as some others on here, but the issues I've had have been covered.
1. Belt tensioner bearings were shot @ 16K - replaced under warranty
2. Timing chain knock on cold/warm startup @ 17K - Repaired under warranty. (Replaced valves in the timing chain case to retain oil pressure)
Other than these two items, I've had no issues with my car and absolutely love it.
Good luck!
Old Jan 19, 2015 | 12:21 PM
cfmistry's Avatar
Originally Posted by Nickanna
Hello and welcome!
Good luck!
Nick,
Thanks for the response. Those seem like rather surprising and significant issues - do you know if they are common on the 3.5L engine?
Thanks,
Cyrus
Old Jan 19, 2015 | 12:27 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I have enjoyed my 2013 C350 since new (October 2012). I have not had one issue with it and I have just passed 18000 miles
Old Jan 19, 2015 | 12:47 PM
Nickanna's Avatar
C63 Coupe
Originally Posted by cfmistry
Nick,
Thanks,
Cyrus
There are a few threads on the knock issue, but nothing on the belt tensioner. It didn't appear that either hit a large number of cars. The knock issue was resolved and MB incorporated that fix after a certain engine build (see below).
Engine 157:
1) From engine number 157 9xx 60 009368 up to engine number 157 9xx 60 017984 install check valves and chain
tensioners
2) From engine number 157 9xx 60 017985 up to engine number 157 9xx 60 022333 (December 2012) install check
valves (optimized tensioners installed in this production range)
Engine 2768:
1) Up to engine number 276 8xx 30 000790 install check valves and chain tensioners
2) From engine number 276 8xx 30 000791 up to engine number 276 8xx 30 001281 install check valves only
Engine 2769:
1) Up to engine number 276 9xx 30 365996 install check valves and chain tensioners
2) From engine number 276 9xx 30 365997 up to engine number 276 9xx 30 406603 (February 2013) install check
valves only (optimized tensioners installed in this production range)
Engine 278:
1) Up to engine number 278 9xx 30 073273 install check valves and chain tensioners
2) From engine number 278 9xx 30 073274 up to engine number 278 9xx 30 103675 (February 2013) install check
Here's a thread on the knock I had found: https://mbworld.org/forums/c-class-w...ine-knock.html
As Capt_Paul said "No issues" in his ownership. If it's the car you want, get it! You'll be fine
-Eric
Old Jan 19, 2015 | 07:00 PM
cfmistry's Avatar
Eric,
Thanks for the great information. As usual, it seems MB is taking care of their customers. I will make sure I buy a vehicle in warranty and have this addressed if need be. Back to C350 shopping! They're certainly a rare breed compared to the C250 Coupe.
Cyrus
