Camber kit
Old Mar 11, 2016 | 04:11 PM
icedelman1's Avatar
2012 C250 coupe
Camber kit
Does anyone know if there is a camber kit for the C204 coupe. Some places say they have them and others say its only for the 4 door.
Old Mar 14, 2016 | 01:11 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
YES THERE IS TOE ONLY ADJUSTMENT OEM.
WE SAW THE NEED THEREFORE TO MANUFACTURE AND REINSTATE FROM THE EARLY 90’S PRECISELY ADJUSTABLE (SINGLE WRENCH, ON CAR) FRONT CAMBER AND CASTER AND REAR CAMBER (WITH EXTRA TOE) KITS TO SUIT VIRTUALLY EVERY MODEL MERCEDES THROUGH TO 2016! INCLUDING ALSO AMG AND BLACK SERIES.
WITH K-MAC THE OFTEN HEARD REASSURING STATEMENT – “FULL FRONT AND REAR WHEEL ALIGNMENT” AGAIN MEANS WHAT IS SAYS!
CAMBER – Allows to actually change the tire contact angle resolving costly, premature edge wear and improving traction/understeer/oversteer (TOE – only alters wheel direction)
CASTER – Correctly resolves steering pull, increases steering response. With better turn in and high speed directional control, along with improved anti dive/lift under brake and acceleration.
Fixing it right the 1st time – no more ongoing trips to dealers or alignment shops or constantly changing tire brands because of “Toe only adjustment” OEM or the frustration of fitting the “front only” inaccurate (one only position) offset bolts to find just provide a minimal .3 of one degree change!
We have changed all that. Up to 4 times the adjustment range of these “one” position bolts. With single wrench precise adjustment and importantly on car accurately (under load) direct on alignment rack!
This K-MAC patented design break through of on car adjustment has also eliminated the need over the last 40 or so years of time consuming disassembly each time to change a setting.
Allowing to return to factory specs anytime after altering vehicle height, fitting wide profile tires, load carrying and/or curb knock damage.
ADDED BONUS IS THESE 4 FRONT AND REAR K-MAC ADJUSTABLE BUSHINGS also replace the highest wearing suspension bushings at the same time – with twice the load bearing area of OEM. Yet still 2 axis/self aligning without the use of oil and air voids which allows also improved brake and steering response.
Both front and rear kits come with bush extraction insertion tubes and instructions.
W204
Front Camber and Caster kit #502616K $480
Rear Camber (and extra Toe) kit #502226K $480
MB World members (USA/Canada) delivery $30 one kit or $40 front and rear.
Can pay by PayPal or call our toll free number 1888 414 0762 to quote Visa or MasterCard.
Old May 7, 2016 | 06:13 PM
icedelman1's Avatar
2012 C250 coupe
Thank you for the info. Glad to know that it is possible to get, will be contacting you soon.
