Clock spring recall...parts are in!!
I am also getting my sunroof bolts tightened as I have the popping sound when going out an uneven driveway
as posted here by another user:
40495 PANORAMIC ROOF GUIDE RAILS BOLTS LOOSE. REMOVE HEADLINER, REMOVE AND REPLACE ROOF RAIL BOLTS, ADD LOCK TIGHT AND TORQUE TO SPECS.
has anyone gotten the recall fixed yet?
Mercedes-Benz says airbags may deploy if the steering-column clockspring breaks and exposes the components to an electrostatic charge. The clockspring is a rotary connector that allows the steering wheel to turn without disconnecting the electrical wiring inside. If the clockspring breaks due to wear, the airbag light will illuminate. Only if that happens, according to Mercedes-Benz, is there imminent risk of the airbag deploying. Dealers will repair the steering-wheel module with sufficient grounding starting in December.
Fletcher Jones, Newport Beach 🏖
courtesy loaner Tuesday till Saturday also. It was a GLC3000
