Please help me identify this broken pipe/hose!
Old Jun 29, 2019 | 04:32 PM
user 843034's Avatar
C250
So I got the P0340 trouble code and the car started sounding like a diesel when starting up. Everything else ran fine after. I came on this board and thought I'd be replacing the cam adjuster sprockets and timing chain at a minimum. I opened up the hood and discovered this hose or pipe broken/missing.
1) Could someone identify this for me please?
2) Could this be causing the P0340 code and issues?
Thanks in advance!
Old Jul 15, 2019 | 05:07 AM
The Critic's Avatar
none yet
You need part #271-090-20-29, list price is $270.
The broke hose is part of the air intake tube assembly. I do not believe it is available separately?
When installing the new air intake pipe assembly, use dish soap to lube the ends - it will make install a lot easier.
