W204 C250 Sport Button Stuck & Faulty Level Sensor
Old Jan 5, 2023 | 08:03 AM
Mattvam's Avatar
C250 W204 Coupe 2011
Hey all
I have an issue with my C250 CGI 2011 where my sport button (Advanced Agility Control - changes suspension settings etc) is constantly active.
I have also plugged in STAR diagnostic which pointed be to “C15221C The right front level sensor has a malfunction. The voltage value is outside the permissible range.
I have been quoted £160 by MB for the “A000 905 02 01” headlight / suspension levelling sensor but there seems to be plenty of these used online for fraction of the price .
I’m wondering if I could use a front left on my faulty front right side (sensor only) or is it part or a bigger assembly? Is it a big or awkward job that requires mercedes to level the suspension?
would this be the sensor that I am looking for?
https://www.ebay.co.uk/itm/385136532693?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=0Ac6i_BnQ8q&sssrc=2349624&ssuid=Ie70WGirT5 i&var=&widget_ver=artemis&media=COPY
thank you all!
Old Jan 12, 2023 | 11:22 AM
JoshyBoy's Avatar
Mercedes
Hi Matt
Did you manage to find out if this is do-able or not. I have the same problem with my car.
Let me know, Thanks
Old Jan 13, 2023 | 05:24 AM
Mattvam's Avatar
Originally Posted by JoshyBoy
Hi Matt
Let me know, Thanks
getting the part replaced tomorrow will let know of results but I don’t believe it’s possible to separate sensors and use on handed units
Old Feb 1, 2023 | 01:42 PM
JoshyBoy's Avatar
Mercedes
Did it work?
Old Feb 2, 2023 | 02:04 AM
Mattvam's Avatar
Did it work?
It has actually worked, replacing the whole unit which cost a whopping £160 at main dealers fixed the whole issue, it also appeared as this unit on my other side had only had the plastic arm replaced I believe it may be possible to exchange these if you get a second hand part but I can’t be sure. Good luck!
