Reversing camera fault
Old May 11, 2018 | 02:20 PM
norman.hamilton's Avatar
MBenz C205 250d
I have a 2016 C205, the camera opens momentarily on reverse being selected and then closes after a few seconds It won't open to allow cleaning
Any members have any thoughts on what the fault could be
Old May 14, 2018 | 03:57 AM
guhvies's Avatar
2017 C43 AMG Saloon
Are you selecting reverse and the switching the engine off? Or are you selecting reverse and getting someone else to clean the lenses while you're in the car with the engine still on?
Old May 14, 2018 | 05:00 AM
MBenz C205 250d
It opens for a few seconds when I'm reversing then closes It won't open at all to allow cleaning which is the only other way of opening the camera
Old May 15, 2018 | 03:06 AM
MattC300Coupe's Avatar
C300 Coupe
You can control this from your vehicle settings. You don’t need to select reverse! There’s a menu on vehicle settings to switch on the reverse camera to allow cleaning.
Old May 15, 2018 | 03:51 AM
MBenz C205 250d
Thanks but I am aware of this function and as I've already stated it won't stay open to allow cleaning
Old May 15, 2018 | 03:57 AM
C300 Coupe
Hmmm... how about when stationary and in P, press the camera button? Does that do anything? It should engage the cameras.
Old May 15, 2018 | 04:24 AM
MBenz C205 250d
By camera button i assume you mean the cleaning function in settings I'm not aware of any other button
Old May 15, 2018 | 04:58 AM
C300 Coupe
no - I’ve got a button above the headlights switch that has a camera icon on it.
Old May 17, 2018 | 03:59 AM
MBenz C205 250d
no button on mine
Old May 17, 2018 | 11:50 PM
MBenz C205 250d
well I removed camera and mechanism and reinstalled it and revisited all connections inside the boot/trunk and it now works. Checked with the dealer re software updates etc and my car is up to date.
So alls we’ll that ends well.
Thanks everyone for the reply’s etc
Old May 24, 2018 | 04:30 PM
mhabashy16's Avatar
2017 C300 Coupe
I have a c300 coupe, i had similar but slightly different issue. Sometimes the camera would open but would show whats on the left side of the car. The screen is basically vertical. The dealer recalibrated the 3 cameras (since they are 3 cameras that show one image) and I dont have this issue anymore. However the issue that persists is that sometimes while im reversing the camera would close and re-open after a second or two.
This is different than your issue however still an issue with the camera. Software on my car is also up to date.
I know this does not help resolve your issue, just letting you know that you're not the only one with issues lol.
