MB Entry Navigation SD NAV Card for 2019 C300
Thanks for the information but I have that card .I brought one and it didn’t load,vendor exchanged it for me.When placed in
the slot all I get is a message to install a compatible sd card or consult my Mercedes Benz partner fo system software updates. Version 16/ 26.00
2023 AMG EQE 53
Not sure but from the pic of your card it looks as if the little white lock switch might be in the wrong position as compared to the pic I sent, check it and maybe slide to the other position. If the car can't write to the SD card the install will fail. Did the card conf from the dealer or another seller? If your dealer no issue, if another then good luck b/c your dealer may just throw his hands up and point to where you bought it.
2019 C300 4matic AMG trim
It’s been a minute but here’s a update.Took the car in for Service and told the service advisor about my issue.She said they would look into it.She comes back later and tells me they would have to download some info from a thumb drive and they did not have it . I thought that was strange because the only place that could be loaded is were the android auto connects. By the way does any know about a MB site SD card manager ?
#32
2023 AMG EQE 53
Sorry but your SA doesn't seem to know. The only thing you need is the SD card and it goes in the SD card slot, it will auto run, load things up and you're ready. No USB stick it anything. Find someone that knows so etching about the car, you are at an authorized MB dealer 🤔
#33
Did you buy a car with Navigation shown as an active feature or you just bought a card and inserted in to SD slot and "Navigation" became availalable? My VIN does not have a dealer SD card available and one from Amazon has not worked.
