Creaking noise from dashboard
Old Oct 29, 2025 | 01:00 AM
munich55's Avatar
E55 AMG W210 - sold, E55 AMG W211 - sold, CLS 500 C219 - sold, E63S AMG W212 - sold, C63S AMG A205
Hey everyone,
I got an 2018 convertible and i'm getting some creaking and squeaking noises from the dashboard area, right below the windshield (possibly from the air vent panel?).
I’ve tried using plastic wedges and silicone spray, but it didn’t make any difference.
I’ve seen a few others mention similar issues, but I haven’t found a real fix yet.
Anyone managed to solve this?
Old Oct 31, 2025 | 09:38 PM
Alexie's Avatar
That's a really common and annoying issue. The creaking is usually the plastic dashboard trim rubbing against the windshield.
Silicone spray often doesn't work because it can't get deep into the clips. The real fix is to carefully remove the long trim piece that runs along the base of the windshield. Then, wrap its plastic clips with Teflon tape or felt tape before reinstalling it. This cushions the contact points and stops the noise.
Old Nov 9, 2025 | 12:48 AM
munich55's Avatar
Thanks for your response!
it tried to figure out were it could come from but the dashboard ends up before the windshield. There remains an littke gap.By the convertible i can't find another plastic trim weich can be removed.
Attached the anoying noise:
Old Nov 10, 2025 | 09:13 PM
Alexie's Avatar
https://youtube.com/shorts/BkUsIiZ9J...R4oe25t5D2mVoP
That gap at the base of the windshield is a common culprit. Leaves and debris get trapped there, clogging the drains. Use a soft bristle brush and compressed air to carefully clear that channel. Check under the car to see if water starts draining out.
Old Dec 2, 2025 | 08:49 PM
Dennis-CCB's Avatar
2016 C200 Coupe
Creaking stops after replacing windscreen
Oh yes, i kinda concur with you...i have the same issue but it is "solved" after i replaced my wind screen due to a huge crack. Hopefully the annoying sound won't be back.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
