front brake pad replacement
Old Mar 15, 2005 | 06:14 PM
flintstone168's Avatar
1997 C230
Anyone has a DIY instructions for replacing front brake pads and rotors for a 97 c230 (w202)
Thanks in advance
Old Mar 15, 2005 | 07:52 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
I thought I saw a DIY on mercedesshop.com that comes pretty close to it.
Old Mar 15, 2005 | 10:19 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Thanks in advance
I did my 97 C280 yesterday, and apparently there might be two different kinds of callipers and pads in 97 that attach differently as I was sold a set of pads that didn't fit my car, and the parts people had to check with my VIN to exchange for the correct set of pads.
My 97's front brakes are exactly like my 98 BMW 528i and my prior 97 Range Rover. You need a metric allen wrench, a pair of pliers, a pair of needle nose pliers and a few different sized screwdrivers.
On the back side of the calliper there are two plactic tubes with plastic caps on them. Pull the plastic caps off and use the correct size allen wrench to unscrew the part that holds the pads to the calliper. That was the only tricky part the first time I changed this type of brake pad.
good luck.
Old Mar 16, 2005 | 08:35 AM
Benzmeister's Avatar
199 C280
Love the wheels, I wished I bought the sport version
just to get the wheels. I am going to post some pics of my "turner" 99 C280 this weekend.
Benzmeister, aka Al
As far as the front pads. On my 99 C280, if was easy to replace them, release the clips and lift them out. You might have to open the bleeder valve to compress the piston, but there are piston compression tools out there, but open the valve and letting a bit of fluid escape is better to compress. Make sure you top off the brake fluid ONLY WITH MERCEDES BENZ BRAKE FLUID. I learned a very expensive lesson with aftermarket fluids.
