problem with reset lights and asr
Old Mar 24, 2005 | 01:49 AM
pl3az3r's Avatar
w203k,w202k,w201,w124
HI all, i really need your help, in my dashboard the service light blinking ( wrench symbol and 24000) i've been trying all combination of reseting procedure it wont go away, so please help me out on this thank you,
oh by the way my asr llight also on now, is it bad? some people told me maybe the brake switch needs to replace or clean, if you guys have more info on this please let me know... thanks guys...
Old Mar 24, 2005 | 01:50 PM
Spriro's Avatar
1999 C280
Here is a post on resetting the FSS (Wrench Symbol)
https://mbworld.org/forums/showthrea...ight=FSS+Reset
On the ASR light, yes, it is PROBABLY the brake light switch. The part cost around $20.
In case you did not notice, your cruise control probably not working either while that ASR light is on. It should work after you correct the problem.
Old Mar 30, 2005 | 11:25 AM
pl3az3r's Avatar
thank u spriro
Thanx man it worked and now im going to take it to tyhe shop for the brake switch.
Old Apr 21, 2005 | 12:43 AM
benz98's Avatar
1998 C230
thank you it works!!!!
Old Apr 29, 2005 | 07:18 AM
Pigzmickey's Avatar
1998 SL 600 ///AMG. 1997 SL 320. 1999 SLK 230K. 2001 BMW R850.
Just worked on a 99 SLK 230K as well, Cheers!
