Rim Measurments Please
Old May 10, 2005 | 10:48 PM
aKaKong's Avatar
94' C220 [W202]
Hey guys.
W202 '94 c220, anyone know the specific measurments of the rims to look for that will fit? yes im a noob, lets all point and laugh at me =]
Old May 10, 2005 | 10:52 PM
c280_nz's Avatar
well 18" rims with 35-40 offset will fit, as these are on myne.
5*112.3 i think is the stud pattern, not sure bout 17s and 19s but sumone with them will. :-)
how often do u update the miles on ur far fetched signature, after every drive :-p
jks
Old May 10, 2005 | 10:58 PM
aKaKong's Avatar
94' C220 [W202]
jks
haha actually, i just made the sig tonight. im past 148,000. but its saved as a PSD photoshop file anyhow so if i ever wanted i can just edit the text layer.
but thanks about the size. is the 5*112.3 just for the 18"s?
Old May 10, 2005 | 11:04 PM
Gregs210's Avatar
2001 E320 (210.065), Brilliant Silver; 2002 Ducati ST-2, Arrest-me Red
Smile everything but the G
Hi, all the MBZ cars (and the ML) use 5x112 bolt pattern.
Most of the sedans use something around an ET35 offset. If you go wide you need a bigger offset or a spacer.
Diameter doesn't matter; I've seen 20s on a C but I wouldn't want to ride in it (I think they were 25 series tires, horrible ride quality). Obviously as you go up in diameter you have to reduce series (sidewall height) or the tires won't fit. There are a bunch of calculators on the web and tirerack has one if you punch in your car year/model it will give you the recommended upsizes (use the wheel search, then choose wheel/tire packs after you pick a diameter).
Happy wheel searching and enjoy the ride,
Greg
Old May 11, 2005 | 04:28 PM
VIP_MBZ's Avatar
Just posted this one on club202. No rubbing, no spacers, fender rolling, or cutting. 18x8.5 +35 front w/235's, 18x9.5 +35 rear w/265's. Rear has lip, front clears AMG/Brembo brakes with no spacer.
There's no way you can use 35 offset as a general rule without considering the width. If you're only going 8" wide all around, 35 will clear with plenty of room to spare. With 8.5 and 9.5 it's very very close.
Use this as a guide only, as wheels and tires differ in shape. Your mileage may vary.
-Ray
Old May 13, 2005 | 06:36 PM
KenzBenz's Avatar
1995 C36
those 265 tires are sickkk man.
