losing power !!
1995 , C220
losing power !!
hello all, 95/ c220 . I am losing power sometimes with this car. I have checked the spark plugs and filters but didn t have any luck. do you guys have any ideas why that happens? the car runs fine except that problem. thanks
1995 , C220
the car goes dead. I have to pull over put my hazards on and restart again then it runs fine for a while.no check engine light is on. I am the 2nd owner and I am not sure if the air mes sensor ever changed. thanks
Originally Posted by C43AMG
I would check the Mass Air then I would check the O2 sensor(s).When was the last time the fuel filter was changed ?
1995 , C220
I don t know when the fuel filter was changed but I will go ahead and change that. air mass and O2s must cost a lot. how do I check if they are working properly without changing them? 95/c220/127,000 miles. thanks
a bottle of RedLine ( my preference ) Fuel System Treatment and add that to your gas tank.If its the fuel filter - you'll know right away , the fuel treatment may take some mileage to restore the performance.If its still running the same with no "CEL" I would take it in and have someone take a look.Let us know how you make out. Good Luck !
