Knocking on startup ?
Old Jul 9, 2002 | 02:08 AM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
I have a 1998 C280 Sport, 52K with the Starmark and when it's started after sitting over night it knocks for about 1 to 2 seconds(like a bearing is bad or from lack of oil). I bought the car with 50K on it and just noticed the knocking the last 2 or three days. And ideas ?
Old Jul 9, 2002 | 04:08 AM
J__'s Avatar
J__
2012 C200 CGI
hmmm... i have knocking noise (kinda like the defective a/c rythmic noise knwn in w202's) but its in the front left side.. not wen i start up but wen i stop after driving at high speeds.. dunno
Old Jul 9, 2002 | 08:21 PM
Nektopoli's Avatar
Sounds like you might have a tire out or round or with a flat spot.
Old Jul 9, 2002 | 08:25 PM
J__'s Avatar
J__
2012 C200 CGI
it cant be... it only has that sound when im at a dead stop... like a rythmic thump every second from the front left engine compartment... i got outta the car and it sounded like its coming from the wheel well, and it stops after like 2 mins or so stopping after i drive around
Old Jul 9, 2002 | 08:29 PM
Nektopoli's Avatar
Does it only happen when with the engin running ?
Old Jul 10, 2002 | 12:58 AM
J__'s Avatar
J__
2012 C200 CGI
yes it does.. i thought it was normal since jap cars wen they're turned off have that tinking sound.. i still dont knw wat it is but its on every car so im assuming its normal.. but mine it has a knocking(light thump..thump..thump.. not tinking) sound only wen its running.. its noiseless wen its shut off, even after long drives
do u knw the reason?
Old Jul 10, 2002 | 09:45 AM
Nektopoli's Avatar
You might have a bad rod, that tinking sound on Jap car after shut down is the exhaust, I don't know what but it have to do with the heat shield being used. Does you car still have a warranty ?
Old Jul 10, 2002 | 07:34 PM
J__'s Avatar
J__
2012 C200 CGI
nope =T no more warranty =T
so its a bad rod u think? whats the rod for? it is really necesariy to fix it? and how much would it be if i had to do it? thnx for ur help
Old Jul 28, 2002 | 12:02 PM
My97C280Benz's Avatar
97 C280 Mercedes
Mine gets it to (cold Engine Knock) it does it allot. No matter what oil I use, I thought it was a bad rod pinging to. I guess ill know if the motor goes bad =(
Old Aug 18, 2002 | 01:34 AM
zul's Avatar
zul
knocking on start up
Have you shecked the oil filter. Some oil filters do not have the stop valve, this would allow the oil in the gallery to flow back into the sump when engine is turned off.
Old Aug 19, 2002 | 02:00 AM
97 C280 Mercedes
No I have not checked that. Any part number or recom.. for a good filter to use?
Thats easily accessible in the states?
Dmaon
