Tension Belt Recall-What Happened
So when i got my car back they gave me a list of what had to be repaired..?!
Bushing, Control Arm-lower-2.5 hours of work at 443.95
Bushing, control Arm-lower-2.5 hours of work at 443.95
Cooling System Flus-.70 hours-122.38
Air Filter Element-.30 hours-61.07
Spark Plugs-3.6 hours-826.70
Brake Fluid-.50 hours-82.31
Fuel Filter-.70 hours-238.13
Brake Discs and Pads, Rear-2.60 hours-650.39
For a Total of $2218.49
Now this is crazy amount of money.... and i dont even know if these are actual "Repairs"
I hope most of these are repairs that i can do. It would be great if you guys can send me links to do the repairs and where to get the parts... and how to check if these repairs are legit.
I'm currently in the middle of getting my oil pan repaired from the bad HB kicking the **** out of it and causing a leak.
My car is also making a clicking noise when the AC compressor spins caused by a semi-loose belt tensioner. My mechanic has found the problem and the part is about $250ish. Anyone know if there is a recall on this part????
TIA
