headlight Assembly
Old Aug 8, 2002 | 04:54 PM
Matt H's Avatar
'96 C220
headlight Assembly
Anybody out there have, or know where I can get ahold of a passenger side headlight assembly('96)?
I REALLY only need the bulb retaining clip for the driver's light. I was changing the bulb out in the dark and it popped off and I can't find it anywhere. Seems crazy to buy a whole new assembly for what amounts to a paperclip.
Anybody know of a body shop or something that may have one crushed up?
Matt
Denver, CO
Old Aug 8, 2002 | 05:00 PM
super3day's Avatar
1997 C230
check ebay.com search key word "W202" and you will see one used head light assembly for bid item #1849060063, i don't know if this is the one you are looking for. anyway, starting bid is $1.00 only. so go to check it out and good luck.
Old Aug 8, 2002 | 05:07 PM
SLK Boy's Avatar
2002 C320
Contact Pat @ Potomac Auto...they've got tons of stuff, and I'm sure he can hook you up...tell him Jimmy from Benzsport sent ya..
benz69247@lycos.com
if you want to wait a little bit, i can probably sell you mine since i'm switching to a 98-on e-code headlight.
Matt H's Avatar
'96 C220
It say's 97-00 but I seriously doubt that MB would change the configuration of a retaining clip. I'll keep my eye on it. Thanks for the information.
Old Aug 8, 2002 | 05:10 PM
Matt H's Avatar
'96 C220
I've give them a call. I think I've contact them before and they wanted me to get the whole assembly to. I really only need the clip and would hate to drop 50+ bucks for a paper clip.
Old Aug 9, 2002 | 12:33 AM
SLK Boy's Avatar
2002 C320
Hmm..the retaining clip for the 94-96 and 97-00 are different...the older headlights used a 9004 bulb, and the newer ones used a H7 from what I remember...so the clip is probably different..
just use a paper clip. or something a little stronger...i'm sure you can find some suitable wires at home depot or something...
good luck!
Old Aug 9, 2002 | 12:46 AM
Matt H's Avatar
'96 C220
I'm using an H7 for sure. But you might be right, I might be able to rig something, I just hate to do it!
Old Aug 9, 2002 | 03:32 AM
super3day's Avatar
1997 C230
i have same experience here, my child safety lock switch (for rear windows disable function) located on the shift gate fell off. I called around all MB dealer and they are asking $100+ for a complete shift gate switch assembly (it only came like that). I will not spend $100+ just for the top piece of safety lock switch, but without fixing it, the rear door power window does not function for rear passenger.
I found a little springs from a die cast model's suspension, and insert it into the hole where the safety lock switch used to be. The metal spring will act as a metal bridge connecting two metal piece to enable the rear power window operation. To cover the hole, I found one expired credit card, the color of the magnetic strip on back of the card match the color of the wood on shift gate. I cut a piece a little big larger than the hole and force it to cover the hole. This plastic piece will blend in with the wood and hold metal springs in the position to have contact points.
Now the rear window can be rolled up and down from the switch on the rear door panel, but no child safety lock function.
If I don't tell anyone, no one willl know it used to be a sfety lock switch at that location.
Total cost for this project $0.
Total hour spend: 1/2 hour.
Result: 90% satisfy
Old Aug 9, 2002 | 10:29 AM
Matt H's Avatar
'96 C220
Sounds like you are a regular MacGyver. You'd think a salvage yard could get you hooked of for cheaper than the Stealership.
I think I'll take the assembly out tomorrow and see what I can' get accomplished. But obviously, I'd love to have a real retaining clip.
