odometer
Old Sep 22, 2006 | 02:34 PM
99BenzGirl's Avatar
99 C230K
Exclamation odometer
Hi Guys, I just got my 99 C220... I just had it serviced and the bell still goes off everytime i get in the car that says it needs to be serviced... how do i reset that.... its already at negative milage.
Old Sep 22, 2006 | 04:03 PM
Denlasoul's Avatar
1998 C43
If you got it serviced at the Dealer, take it baack and have them reset it for you
or
Look through your Owner's Manual for the FSS reset explanantion.
Old Sep 22, 2006 | 05:43 PM
99BenzGirl's Avatar
99 C230K
Smile
thanks.... I looked in the book and it says to take it to a dealer, problem is i live over an hour from where i got it serviced. Wanted to see if there was a simple fix someone out here knew about.
Old Sep 22, 2006 | 06:42 PM
xvvvz's Avatar
C230K
Are you sure you have a 99 220 U.S. car? Maybe 230 Kompressor or just a 230? Even if you have a 220, their is a sequence of buttons you press to reset it. You can call the 800 Mercedes help line if you don't have a manual and they should tell you how to do it. You might want to watch for a used manual on Ebay.
Doug
Old Sep 23, 2006 | 01:36 PM
Denlasoul's Avatar
1998 C43
http://www.club202.com/forums/showth...ight=reset+fss
Old Sep 25, 2006 | 12:14 PM
99BenzGirl's Avatar
99 C230K
Doug
You are right LOL i cant believe i messed that up it is a C230K and still no luck resetting it
Old Oct 5, 2006 | 12:38 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
1 Insert the ignition key and turn it to
position 2. Immediately press button 0 on
the instrument panel twice within one
second.
2 Turn the ignition key back to position 1.
3 Press and hold button 0, then turn the key
to position 2 (keeping the button
pressed). The display will show the
current remaining distance or time, and
after 10 seconds an acoustic signal will
sound. The new starting distance or time
will appear for about 10 seconds on the
display.
4 Release button 0.
Old Oct 10, 2006 | 11:49 PM
MBHustla858's Avatar
my 99 manual shows how to reset the light.....
