High pitched whining sound from behind dash when engine running
Only does it when the engine is running, not if the accessories are just on. It sounds like it's coming from directly behind the passenger air bag, as if I put my ear on it, it is the loudest.
I have no clue what it is. It does it with the radio turned off, and the vent and a/c turned off. Maybe some sort of pump?
I did a search but couldn't find anything simliar to this.
Thanks,
- Anthony
I'd inspect it for water damage, but you'll at least need a blower regulator, possibly the blower motor.
You really only hear it if you are light on the throttle, or off the throttle completely, or on the brakes. It seems that under moderate/heavy throttle, the noise is gone.
I really can't pinpoint where it is coming from, but man it's annoying. At first I thought it was the brakes, but it's not the right type of sound. This sounds more like an electical whine than a brake squeal.
Any ideas? It does it both when the HVAC unit is on, and when it's off, so I'm not sure if it's the blower motor.
